Wild Bunch Trial Stage POSTPONED till Oct Match
Started by kid ziggy, September 16, 2018, 10:01:15 AM
Previous topic - Next topic
kid ziggy
Sorry .... have a commitment the 29th I had forgotten about and will not be at TMM.
Let's plan on doing the WB training and trial stage right after the Oct match.
For those interested you will need the following guns and ammo:
Semi-auto pistol... (1911 preferred) - 9mm or bigger with three magazines - 7 rounds per mag
Rifle ...  Any main match SASS rifle
Shotgun ... 1897 pump (preferred)  -  any pump or lever SG ok (up to 6 rounds in mag)
AMMO needed for stage:
Pistol ... 21 rounds (lead preferred but jacketed okay ... we will be shooting far enough away from target to remain safe
Rifle ... 10 rounds (lead)
Shotgun ... 6 rounds  (magazine will be stoked with up to 6 rounds ... extra rounds from body or table)
You might scan through the wild bunch rules (SASS main website link) if you plan to attend.  We will be following the SASS WB safety rules & loading/unloading techniques.
Outcast
Thanks Ziggy! I really appreciate you doing this. Wild Bunch is something I've wanted to learn about for some time now.  It would be nice to have 3-5 folks to start with. It will take some effort to set up and make it go. After the initial in-service we will move the actual side match to the morning. Below is a link on SassNet.com to the Wild Bunch Rules.
I really hope we can get a few more folks interested.
https://www.sassnet.com/Downloads/WILD%20BUNCH%20Action%20Shooting%20Handbook%20Vers%2011_3.pdf
Hurricanecharly
I will try it!
I will never have a chance this close to home with relaxed gun requirements under friendly guidance and familiar territory  again!
I don't want to miss a good opportunity!
Purly
You can count me in. I neef to find another mag. Any ideas where I can find one for a S&W 5906.
Territorial Governor
kid ziggy
Don't worry if you do not have leather, etc ...  We will allow staging on table
Food for Thought:   One of the main safety issues for any of the pistol shooting disciplines is placing your trigger finger OUT of the trigger guard during any moving, changing magazines, drawing, clearing, etc ...
The only time the trigger finger is on the trigger is at the firing line with the gun pointed down range aimed at your target.   Once the shooting string is done for that position, the shooter must place the trigger finger outside of the trigger guard in a way that clearly shows it clear of the trigger.   This is a critical safety practice for every situation ... that we don't require in cowboy shooting.  It is why we don't have movement or start with live rounds in the chamber in cowboy shooting.
Picking up your firearm from a table,  or drawing from a holster with your finger on the trigger IS NOT ALLOWED (or safe) anywhere else!   If you only shoot cowboy action ... please work on this before the WB activity at TMM.
Hurricanecharly
Good point that most of may not be aware of Ziggy!
I believe you can get a lot of us up to speed with these types of post!
Can't wait to shoot the d$%&^%$!  97 with six stoked!
Dirtwater Fox
I am also looking forward to this opportunity to learn about WB count me in
Purly I may have a mag like you are looking for I will go through and see. If I do I can bring it to lead mine valley shoot.
Purly
Outcast
Slater will probably participate. Pole Cat is interested. You guys help me lean on him.  ;D
kid ziggy
Quote from: Hurricanecharly on September 18, 2018, 08:53:10 PM
Most of the Norinco 97 clones will only hold 5 SG shells in the magazine.   Also, if you are going to use a modern pump like a Remington 870, you might only get 3 or 4 in the magazine.   The chamber will be empty, so you will be charging the gun after you pick it up.
Outcast
I have no clue how many mine will hold. Guess I should check?
Hurricanecharly
Me either! I'll check tommorrow.
A very good friend gave me a model 12 2 years ago 4 xmas..
Is it legal?
Critr
CRITR
kid ziggy
#13
Model 12 is a SASS WB legal gun.   There is an extra safety step the shooter has to do with Model 12s ... when staging shooter has to declare the model 12 to the T.O. and pull the trigger to show the gun is not cocked.  If the action makes a 'click' from the hammer dropping it is a stage DQ even though the chamber is empty.  We will be using this procedure for any pump-action SG that does not have an external hammer.  Failing to declare the Model 12 to the T.O. is also a stage DQ.
When I shot a model 12 in WB matches, I would hang a clip from the trigger guard to remind myself to declare it to the T.O.  & then remove it afterward while staging the gun.
kid ziggy
Quote from: Critr on September 20, 2018, 07:32:28 AM
My 97 Takedown holds 6 in the mag. :P
You can purchase a modified magazine spring for the Norinco 97s that works for 6 rounds.  The stock spring stops just a hair short of allowing the 6th round.  For guns that do not hold 6, the shooter can stoke what it will hold & reload from the body for the remaining rounds.
For WB, there are no SG make-ups.   The only time you can re-load from the body to make-up a shot is when you jack a live round out of the gun.  SG targets left standing at the end of the shooting string are scored as misses.
